Setup problems with the plugin
This is a sticky topic.
  • #16
    Hi dondi,
    I have tested the device the way you want to control it and everything works with your kind of setup. You are wright to say that your phone is not connected to HomeSeer.
    Did your settings confirm that your are connected to WiFi or WAN? during Tasker setup?
    Eman.
    The People's Advocate.
    • #17
      Hi dondi,
      I have tested the device the way you want to control it and everything works with your kind of setup as long as you add the last Variable " %HSCommand To DeviceUpdate" And use "off" for turning the light off (I think this may depend on the type of controller. I tested with X10).
      Eman.
      • #18
        Hey Eman
        as I said before, I think that the problem is in the phone connection to HS.
        I tried to add the %HSCommand and still nothing happened.
        where can I verify the connection settings between my phone to HS?
        • #19
          Originally posted by dondi View Post
          Hey Eman
          During setup on the phone itself you get pop up screens where you imput your connection information
          Did use this document: https://docs.google.com/document/d/1...t?pref=2&pli=1 durind intial setup? On the phone in Tasker you would run the task with a star where it says "run me". Click on it to open it up and press the play play button on the left at the bottom and follow the instructions. If everything goes well then you are good to go but try also to let the firewall to allow the plugon in HomeSeer if on Windows.
          Eman.
          • #20
            Hi dondi, how are you connected.
            wifi on same network as Homeseer, outside homenetwork, or do you use myhs service to login?
            In Tasker folder on your Android, there is some configuration files.
            Could you share these but mask your private data.
            hs3_connection.dat
            myhs_connection.dat
            ssid.dat
            Tasker Plugin / Speech Droid
            Tonlof | Sweden
            • #21
              Hey again
              I'm using MYHS.
              tried to run the setup again with an error after configuring HS local IP
              • #22
                Ok,
                Disable the check mark for ssl and see what happens.
                For more instructions I refer you to tonlof for the file he asked you. Best to contact him with PM
                I also think the SSL port must exist in HoneSeer settings before use it. Tony is very good at this.
                Eman.
                • #23
                  GOT IT!!!!!
                  the SSl was the problem.
                  now everything is working
                  Thank you for all the help.
                  • #24
                    GOT IT!!!!!
                    Great to hear, on the local network it does not make big sense to use ssl.
                    Tonlof | Sweden
