Tasker 'disappeared' from plugins
  • Tasker 'disappeared' from plugins
    So I'm having the same issue that many others are having.
    I have over 40 plugins and Tasker is the only one with this issue.
    When I logged into my HS3 instance I always look at my plugins, and I noticed that Tasker was nowhere to be seen.
    I will paste the error from the log where I attempted to install it again.
    It appears that it was still running, just not in the dropdown menu, or plugin list?
    It did show up enabled after the install, but was all wonky (the plugin menu indicated that Tasker was having an issue. I disabled it as usual.
    Please help in resolving this issue. It happens multiple times a day.
    This is a fully license plugin.
    Thank you for your time.
    May-10 8:24:01 AM * Plug-In Finished initializing plug-in Tasker Plugin
    May-10 8:24:01 AM * Error (2) Unable to initialize interface Tasker Plugin :Either no license or trial has expired
    May-10 8:24:01 AM * Updater Re-initializing plugin after update.
    May-10 8:24:01 AM * Updater Install/Update of package Tasker Plugin failed.
    May-10 8:24:01 AM * Updater Error Installation of package Tasker Plugin failed. Try disabling the plugin first, then re-try the update.
    May-10 8:24:01 AM * Updater Error Copying source to C:\Program Files (x86)\HomeSeer HS3\HSPI_TASKER.exe, detailed error: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\HSPI_TASKER.exe' because it is being used by another process.
    May-10 8:24:01 AM * Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_TASKER.exe
    May-10 8:24:01 AM * Updater Installing package Tasker Plugin
    May-10 8:24:01 AM * Updater Update HSPI_TASKER.exe downloaded successfully
    May-10 8:23:59 AM * Info Plugin Tasker Plugin with instance: has disconnected
    May-10 8:23:59 AM * Updater Downloading update: Tasker Plugin
    May-10 8:23:59 AM * Warning Problem shutting down plugin Tasker Plugin:Object reference not set to an instance of an object. Line:0
    May-10 8:23:59 AM * Updater Plugin is loaded, unloading before updating.
    May-10 8:23:59 AM * Updater Starting download of updates
    Have you updated to the latest beta of the PI to see if it resolves the issue? That worked for me.
      Do you mean the one in the updater Beta, or the one only posted in the forum?
        I have the latest from the updater.
          I have 3.0.4.0 right now and it seems fine. It does look like 3.0.4.2 is available in the updater as well.
            Yep, I'm already on 3.0.4.2
            It has been having this issues for at least the last few versions.
              Hi, try the download from http://board.homeseer.com/showthread...=181184&page=2 post #27
              Tasker Plugin / Speech Droid
              Tonlof | Sweden
                Originally posted by tonlof View Post
                Now also available in updater BETA 3.0.4.3
                Disable functions for future features, in case this cause issue to some users.
                Tonlof | Sweden
