Tasker Setup for HS3 not working
  • Tasker Setup for HS3 not working
    I am following the directions here: https://docs.google.com/document/d/1...Ro96vbdGc/edit
    And after I download and run the Setup Tasker for HS3, it says it's running and to please wait. Nothing happens. It's been a half hour and nothing happened. Nothing showed up in my projects folder and I ran a search in ES File Explorer and none of the file noted in the guide were installed.
    It looks like the server it's looking for is down.
    Can I just get the zip file from somewhere and install it manually?
    Hi, I will check the server if there is any issue.
    Tasker Plugin / Speech Droid
    Tonlof | Sweden
      It seems to be something wrong with the dyndns service I'm using.
      Send me an PM with your emailaddress if you want me to send the tasker files.
      Tonlof | Sweden
        Sent. It's the same as my name here with @gmail.com
          InstalTasker HS3 problem
          Hi, I also have the same problem. Can you send me the files?
            Hi, you can download the file from this post. https://forums.homeseer.com/showpost...41&postcount=7
            Tonlof | Sweden
