Speaker client
  • Speaker client
    I am new to Tasker, but have communication from HS to tasker and from Tasker to Homeseer.
    I want to use my phone for speaker client.
    I see on the screen of my phone the speaker commands coming in, but don't hear anything.
    How do I setup my phone to speak the homeseer text to be spoken?
    Peter
    http://ohh.pcgsm.nl
    If you have speech proxy selected in the plugin all TTS should go through the phone. There is also an option to only send TTS to the phone as an event action.
    Originally posted by rprade
      If I select speech proxy, I hear all text to my house speakers 2 times.
      But when HS is speaking I see on my phone :
      Received message from Unknown: text:"ref=3812 say=media=:=spoken text" password:"xxxxxxx"
      but nothing from my phone speaker.
      so I guess I have to setup something in Tasker for the thext to be send to my phone speaker?
      Peter
      http://ohh.pcgsm.nl
        Hi Peter, do you have any other plugin that use speechproxy since you have the speech twice? Also check the SAY task in tasker HS3 Engine if there is a line STOP, disable this line.
        The toast you mentioned above is coming from autoremote, you can disable incoming toast in the app to hide it.
        Tasker Plugin / Speech Droid
        Tonlof | Sweden
          Hi Tonlof,
          I found the task SAY, and it has the Stop line.
          But how do I disable the Stop line? (I am new to Tasker)
          Peter
          http://ohh.pcgsm.nl
            Hi Tonlof,
            Is this stop on line 6? Longpress to mark it and then press the "power" icon to disable it. Exit tasker to save the changes.
            Tonlof | Sweden
              Thanks for the help!
              Blocked the line and now speaking is working.
              I assume there is a profile I can set to ON or Off to set the speaking on or off on my phone?
              What profile is it?
              Or must I activate line 6 again to stop the speaking?
              Peter
              http://ohh.pcgsm.nl
                What profile is it?
                Great, this line is disable in the latest tasker files. When did you download these?
                To disable the tasker speakerclient you can just create a simple event in hs3 and "Control a device" select your Tasker device and chose Enable or disable speaker client if you need silent times over the night ex.
                Tonlof | Sweden
                  I started with HS Tasker this weekend.
                  Peter
                  http://ohh.pcgsm.nl
                    Ok, I will check the files and see if the STOP line is disable or not.
                    Tonlof | Sweden
