Best way to disconnect my phone from Bluetooth when at home?
  • Best way to disconnect my phone from Bluetooth when at home?
    I've been missing calls lately because I'm forgetting to turn off Bluetooth when I'm at home. When that happens, my phone stays connected to the Bluetooth adapter in my car. I assume Tasker has a feature that does this? Does it?
    Learn About HomeSeer
    Yep. Net -> Bluetooth Off.
    Originally posted by rprade
      I thought of that about 10 minutes after posting! Thanks!
        So how do you trigger this from Tasker? When you connect to wifi?
        Sent from my SM-G920W8 using Tapatalk
          Automate Wifi, BlueTooth and Mobile Data when you at home.
          1)Install this app https://play.google.com/store/apps/d...nager&hl=en_GB
          2)And this plugin : https://play.google.com/store/apps/d...ifimatch&hl=en
          With Wifi Matic you will not ever need to switch your wifi unless you are doing tests (make sure you set only your SSID). Although you can, don't use this app to control Mobile Data. Just the Wifi. Also there alot more ways you can these. You will find out what suits best.
          Start off by creating a PROFILE : Using state and select the Locale Wifi Match plugin and give it a name say If @home
          For the TASK (name = Home): 1. Wait = 10min (choose your time depending on the property you live in). OPTIONAL
          2.Use Secure Settings to turn off MOBILE DATA
          3 Variable Set %BTCONN to off
          You can also add other things you want like a device in HomeSeer. Then for the EXIT task should be the opposite of the task you created above
          attached is an image of the task
          Eman.
          The People's Advocate.
            Great thanks Eman!
