I have had this before on my tablet, it used to switch its charger on or off with HSSetdevicevalue and HSRef. One day it stopped working. I found a workaround with creating an event on HS3 and trigger that with HSCommand. That works fine. Yesterday my other tablet stopped switching its charger. Today my phone did not switch a virtual switch which has worked for weeks. Whatever device I try to switch, it doesn't work. Again, if I trigger a event to switch the device it works.
My tablets are in the local network, my phone is too when at home otherwise connects remotely, the error is local as well as remotely.
Looking at the HS3 logs, there is nothing when I try to set a device from tasker, so no command arrives, that must be the problem, tasker not sending the HSSetdevicevalue.
There must be something wrong with the plugin. Even though I can get round this by creating and triggering events, it would be good if I have the option of switching devices as it was possible before. And I have tried changing from 0 to OFF, On, 100, 255.... it does not work any more.
