Jun-26 02:45:25
Error
System.Data.SQLite.SQLiteException (0x80004005): database disk image is malformed database disk image is malformed at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain) at System.Data.SQLite.SQLiteCommand.BuildNextCommand() at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index) at System.Data.SQLite.SQLiteDataReader.NextResult() at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavi or behavior) at System.Data.SQLite.SQLiteCommand.ExecuteDbDataReader(Command Behavior behavior) at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteR eader(CommandBehavior behavior) at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet) at HSPI_ULTRALOG3.hspi_database.ExecuteHSLogSQL(String strSQL, Int32& iRecordCount, Int32 iPageSize, Int32& iPageCount, Int32& iPageCur)
Jun-26 02:45:25
Error
Jun-26 02:45:25
Error
System.Data.SQLite.SQLiteException (0x80004005): database disk image is malformed database disk image is malformed at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain) at System.Data.SQLite.SQLiteCommand.BuildNextCommand() at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index) at System.Data.SQLite.SQLiteDataReader.NextResult() at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavi or behavior) at System.Data.SQLite.SQLiteCommand.ExecuteDbDataReader(Command Behavior behavior) at System.Data.Common.DbCommand.ExecuteReader() at HSPI_ULTRALOG3.hspi_database.GetHSLogTypes()
Jun-26 02:45:25
Error
Error
Jun-26 02:45:25
Error
Jun-26 02:45:25
Error
Jun-26 02:45:25
Error
