Pushing data to third party Syslog service
    This is my primary coding goal this weekend. I have my syslog receiver setup and ready to accept HomeSeer log messages
    Ultrajones
      Ok, good that it is only your primary coding goal. I am sure that you have more important things to do.
      But, we do appreciate this feature and have been looking forward to it for a while.
        Ultrajones
        Just a thought..... there are those of us (like me) that would like to use a syslog, but need a bit of tech help/prompting. Is there a good open source way to do this? Where is the best place to install the server.
        HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
        Operating System: Microsoft Windows 11 Pro - Desktop
        Z-Wave Devices via two Z-Net G3s
        Zigbee Devices via RaspBee on RPi 3b+
        WiFi Devices via Internal Router.
        Enabled Plug-Ins
        AK SmartDevice 4.0.5.1,AK Weather 4.0.5.174,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.50.128.5,JowiHue 4.1.3.0,LG ThinQ 4.0.25.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.0.3
          If you are just getting started you don't need anything more than this plugin. It acts as a syslog service along with the benefits of being able to interact fully with the HS3 event engine.
          Currently I am using it to trigger events based on text matches from the HS3 logs AND on text and type matches from my Unifi WIFI logs which are forwarded to the plugin.
          I think the folks on here asking for this enhancement already had standalone syslog servers (I may be wrong on this) but I haven't found any cases that I can't handle with the plugin as-is.
          Give it a trial.
          cheeryfool
              Obviously, then, I'm doing something wrong. Nothing shows in the syslog tab..... Syslog has been enabled for quite some time, yet, no entries in the log.....
              Am I missing a client or starting a service or ????
              Enabled Plug-Ins
                  I am quickly discovering there is no standards when writing messages to the HomeSeer log. I'll do my best to format the output from the HomeSeer log to the syslog protocol.
                  Ultrajones
                    Sure...
                    I would be completely happy with the entire Type/Error and Message/Source fields being in the text body if you know what I mean. So treat all of them as Informational as part of the protocol definition. If I remember correctly.
                    For now that is good enough for me.
                      This is how I have mine configured:
                      In case you have anything different set.
                      HS3 logs just show up with it set this way. For my Unifi logs I just direct them to the HS3 IP leaving the port null, which uses the default syslog port - UDP 514
                      cheeryfool
                        I guess what I'm not really following is whether or not Ultralog3 is acting as a syslog server. I've never had a problem with looking at the HS3 logs, but I've never had syslog working.
                        My configuration is the same as yours, BUT I don't have an Ubiquity router (or even a DD-WRT one).
                        Enabled Plug-Ins
                          Well then, what are you wanting to use the syslog server in UltraLog for? If you don't have anything sending logs to it the syslog portion of the plugin won't do anything. Am I missing something here?
                          Originally posted by rprade
                            Might this be a good time...
                            Was wondering if this might be a good time to fix the records per page item? Currently it is greyed out.
                              No, you aren't, I am.... and that is a basic understanding of what I "know." How does syslog work? Everything I read implies that every network device is a syslog client, by default, and chattering on (at least) port 514. Then, there is a syslog listener listening for the traffic and server accumulating the messages. Is that another piece of software/hardware or, as stated above, is it truly the case that "This plugin is self sufficient."
                              So, I guess my confusion boils down to this:
                              1) Do all network devices send syslog messages and, if so, does it require configuration per device? I.E. does that feature need to be "turned on?"
                              2) What hard and/or soft ware performs the task of listening?
                              3) What hard and/or soft ware performs the task of the server and is it necessarily separate from the listener?
                              4) Where does Ultralog fit into this scenario?
                              5) What do I need to make this work?
                              Either I am guilty of not being able to see the forest for the trees, or this is one of the most poorly explained topics on the Internet.
                              If I am looking at this correctly, many of the recent issues of HS3 errors would have been (for me, at least) easier to comprehend and trace, if I could have aggregated messages from the network computers. If I've got this correctly, I think a lot of other folks would benefit from ULTRA's logging PI, if they knew about syslog and how it works.... if it has the capability I understand it has.... and is implementable without too much angst.
                              Any explanation would be greatly appreciated....
                              Enabled Plug-Ins
