HS Log stop logging
    HS Log stop logging
    Hi Ultrajones, It may be nothing to do with the issue I'm having but is worth mentioning it to you. My HS log after few days stop working after upgrading to .478. I was checking the status of your plugin and I noticed the logs are in queues, I do not remember if they should be inserted into the log. Could it be a lock issue?
    Aldo
    Aldo
    Most of the people who have the HS logging stop still see entries in UltraLog3. Are you sure Logging is enabled in Setup? Even if it is, you might try toggling it.
    Click image for larger version  Name:	Capture.PNG Views:	1 Size:	15.6 KB ID:	1273190
    Seeing 19,263 in the UltraLog Queue is curious.
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
      I checked, it is enabled. Thanks for the tip.
      Aldo
      Sent from my SM-G935V using Tapatalk
