Can I use UltraLog3 to grab a log message to be sent with pushover ?
    I have a event which triggers when
    Z-Wave Error Failed sending Z-Wave command to device
    shows in the log. It then notifies me with a pushover message.
    This is showing in the log:
    Jan-08 16:28:01 Pushover 3P Pushover Notification Sent - Message Title Log Z-Wave Error Failed sending Z-Wave command
    Jan-08 16:28:00 Event Event Trigger "Test Log Z-Wave Error Failed sending Z-Wave command"
    Jan-08 16:28:00 Z-Wave Error Failed sending Z-Wave command to device: Lights Garden Drive lights
    Currently, I only get a message Z-Wave Error Failed sending Z-Wave command to device, but would like to know which device is not responding.
    Basically I would like to send this via pushover:
    Sure. Do an UltraLog3 trigger on the message, then use the UltraLog3 replacement variables in the Pushover Message body. I do that with several different log messages.
    Here is one
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
      Great. Works a treat. I guess it grabs just the log line before the trigger ? I only tested it with a run of the event
