Deep Learning or Machine Learning?
  • Deep Learning or Machine Learning?
    After reading this article here : https://www.iotevolutionworld.com/sm...e-learning.htm and it got me thinking that HomeSeer's Event engine boarders to nearly that and with some clever guys here who can do scripting can make it feel like that!
    Butt there is also the UltraLog3 (Database Logging) HSPI For HS3 with
    [QUOTEMain Features
    • Supports HomeSeer triggers based on text or regular expression matches on HomeSeer log events.
    • Supports syslog triggers based on text or regular expression matches on syslog log events.
    • Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
    • Multiple threading allows UltraLog3 to process caller ID events without disrupting the performance of HomeSeer.
    ][/QUOTE]
    So that said, what if the author of that plugin tweaked it a bit to log to a database like SQLite or other to server to that purpose by (time,weekly and/or by month) Am thinking you could be nearly there! Or maybe not!
    But then again enter Node-RED with this node here : https://flows.nodered.org/node/node-...b-syslog-input I believe you could be able to send the data to it from UltraLog3 (Database Logging) HSPI For HS3 and do some tricks! And not also use the MQTT nodes out back to HomeSeer. I have not played with setup yet but it got thinking if there is someone out there who can elaborate more on this? Pete ?, Anyone?
    Eman.
    The People's Advocate.
