A call was made to save a global variable (LogMessage) but that global variable ...
    Hi, I've recently been getting these errors.
    A call was made to save a global variable (LogMessage) but that global variable has not been defined.
    A call was made to save a global variable (LogType) but that global variable has not been defined.
    I can see the variables listed in the HS global variables page, I wonder if it's caused by the fact that my event was triggered 3 times by matching the word "Error" in quick succession?
    Ultrajones, is this something that can be fixed in the plugin?
    Megaman:
    Refer to this forum thread:
    https://forums.homeseer.com/forum/ul...riable-has-not
      Oops - sorry, I just realized you had started that thread...
      Sheepishly,
      BBB
        I assume you only see those "errors" after a restart of the plug-in and on first use of the global variable, correct?
          Sorry for the late reply - yes.
            It is normal to see that error in the log the first time a global variable is used after a restart. Global variables are not durable - they are lost when HS is restarted. Once they are used they will remain until the next restart. You will only see that error once, after that the variable exists.
            HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
