A call was made to save a global variable (LogMessage) but that global variable ...
  • randy
    It is normal to see that error in the log the first time a global variable is used after a restart. Global variables are not durable - they are lost when HS is restarted. Once they are used they will remain until the next restart. You will only see that error once, after that the variable exists.
  • BigBadBuzz
    Sorry for the late reply - yes.
  • Ultrajones
    I assume you only see those "errors" after a restart of the plug-in and on first use of the global variable, correct?
  • BigBadBuzz
    Oops - sorry, I just realized you had started that thread...
    Sheepishly,
    BBB
  • BigBadBuzz
    Megaman:
    Refer to this forum thread:
    https://forums.homeseer.com/forum/ul...riable-has-not
  • A call was made to save a global variable (LogMessage) but that global variable ...
    Hi, I've recently been getting these errors.
    A call was made to save a global variable (LogMessage) but that global variable has not been defined.
    A call was made to save a global variable (LogType) but that global variable has not been defined.
    I can see the variables listed in the HS global variables page, I wonder if it's caused by the fact that my event was triggered 3 times by matching the word "Error" in quick succession?
    Ultrajones, is this something that can be fixed in the plugin?
