SQLServer 2008
    SQLServer 2008
    I installed SQL Server 2008
    Everything works great from SSMS
    Change type to SQlServer 2008
    Provider to OLE Data provider
    Connection String to:
    Provider=SQLOLEDB;Data Source=HAPC\HAPC;Initial Catalog=HomeSeerDB;Trusted_Connection=yes
    (its an instance called HAPC on a PC called HAPC)
    If I go to options it says online and Server 2008
    When I try to run any query I get this:
    Your query failed for the following reason: System.Data function/subroutine: [13 - Unable to cast object of type 'System.Data.SQLite.SQLiteCommand' to type 'System.Data.OleDb.OleDbCommand'.]
    Restart of a fixed this
    Restarted HS and get this:
    UltraLog Warning - InsertDeviceStatusIntoDB() Reports Error: [System.Data.OleDb.OleDbException: The statement has been terminated.Cannot insert the value NULL into column 'id', table 'HomeSeerDB.dbo.tblDeviceStatusLog'; column does not allow nulls. INSERT fails. at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(Command Behavior behavior, String method) at System.Data.OleDb.OleDbCommand.ExecuteNonQuery() at HSPI_ULTRALOG.Database.InsertDeviceStatusIntoDB(DateTime ts, String hc, String dc, Int32 status, Int32 data1, Int32 data2)], Failed on SQL: INSERT INTO tblDeviceStatusLog (ts, hc, dc, status, data1, data2) VALUES ('8/14/2011 5:31:17 PM',']',']1',17,1,0).
    (I used the table creation strings from the doc on converting for MS SQL 2005, but these didn;t contain the schemas for devicestatus and device value, so I got them from SQLLite with the describe function and run resulting script in SQL Server)
    Any ideas?
    Regards
    mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    Solved that bit by making id's identity fields
    USB UIRT
    2GIG Thermostat
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Global Cache IP2IR
    Foscam FI8918W
