Error Writing to DB
    Error Writing to DB
    I have a few X10 devices that have house codes %1, etc.
    I get an error when they are triggered:
    10/9/2012 10:49:43 AM ~!~UltraLog Warning~!~InsertDeviceStatusIntoDB() Reports Error: [System.Data.OleDb.OleDbException: The statement has been terminated.String or binary data would be truncated. at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(Command Behavior behavior, String method) at System.Data.OleDb.OleDbCommand.ExecuteNonQuery() at HSPI_ULTRALOG.Database.InsertDeviceStatusIntoDB(DateTime ts, String hc, String dc, Int32 status, Int32 data1, Int32 data2)], Failed on SQL: INSERT INTO tblDeviceStatusLog (ts, hc, dc, status, data1, data2) VALUES ('10/9/2012 10:49:43 AM','[%]','[%9]',3,2,0).
    I'm using SQL server for messages and % is a wildcrd. Could that be the issue? Anyone got any idea how to change house codes with X10/ACRF2 plug-in?
    Regards
    Mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    Hello. I added an escape character to the % character. Can you try UltraLog HSPI version 1.2.4665.33287 I just uploaded to the HomeSeer updater?
    Ultrajones
      Ultrajones
      Thanks UJ.
      Will try tomorrow when back home
      Regards
      Mark
      USB UIRT
      2GIG Thermostat
      BLUPS
      UltraLog (SQL2008)
      Jon00 Plugins
      Global Cache IP2IR
      Foscam FI8918W
        UJ, I'm also getting an insert error on devices using the % housecode. It was working with the version you had posted immediately prior to 1.2.4665.32287. I started getting the errors after updating to 1.2.4665.32287.
        [COLOR=#D58000]InsertDeviceStatusIntoDB() Reports Error:  [System.Data.OleDb.OleDbException: The statement has been  terminated.String or binary data would be truncated.   at  System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior  behavior, String method)   at  System.Data.OleDb.OleDbCommand.ExecuteNonQuery()   at  HSPI_ULTRALOG.Database.InsertDeviceStatusIntoDB(DateTime ts, String hc,  String dc, Int32 status, Int32 data1, Int32 data2)], Failed on SQL:  INSERT INTO tblDeviceStatusLog (ts, hc, dc, status, data1, data2) VALUES  ('10/26/2012 11:00:14 AM','\%','\%49',17,790,0).
        [/COLOR]
        HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
        Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
        Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
        Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
          [/COLOR]
          What database are you using?
            Using SQL 2008R2.
              Any updates on this? I saw in another thread you were planning to make the escape character configurable.
                Added it now... I wish I could find documentation showing what characters need to be escaped when using the Microsoft SQL database.
                Ultrajones
                  Ultrajones
                  Hi UltraJones
                  I do a lot of MS SQL dev. I usually avoid these (mostly when using LIKE). Single quote is the main one for a regular query, but I have had issues concatenating strings when there is an ampersand in the string.
                  percent sign (%)
                  underscore (_)
                  brackets ([ ])
                  caret (^)
                  hyphen (-)
                  ampersand (&)
                  single quote (')
                  Regards
                  mark
                  USB UIRT
                  2GIG Thermostat
                  BLUPS
                  UltraLog (SQL2008)
                  Jon00 Plugins
                  Global Cache IP2IR
                  Foscam FI8918W
                    Wow, testing shows I don't need to escape those characters when doing an insert. The error "The statement has been terminated. String or binary data would be truncated" means the escape character is being ignored and treated as a normal string. I am removing it now and will post an update.
                    Ultrajones
                      Sorry for the delay. I had to install SQL Server 2008 Express to see what was going on. I was able to duplicate the issue. UltraLog HSPI version 1.2.4775.22583 just posted which should fix the issue reported.
                      Ultrajones
                        Ultrajones
                        Thank you, Ultra. Where did you post this? I don't see it. Or do you mean you sent it to the updater and it will take a couple days?
                          Ultrajones
                          The only one you should need to escape for an insert is single quote
                          USB UIRT
                          2GIG Thermostat
                          BLUPS
                          UltraLog (SQL2008)
                          Jon00 Plugins
                          Global Cache IP2IR
                          Foscam FI8918W
                            Sorry, missed this question. I host my own plug-in downloads, so as soon as I post them they are available for download via the HomeSeer updater.
                            Ultrajones
