Hi Randy,
I'm having an issue where UL3 won't start anymore. I upgraded to HS3 .152 last weekend and the first time the plugin did not start, but I started it manually after and it was fine. I was working on some other things today that required a HS restart and I had the same issue. However, when I try to manually start the plugin now, it won't restart. I started it from the command line and this is what it shows me:
It's been sitting that way for a while now (10+ minutes) and in the HS log I get the following:
Any ideas? Anything I can do to troubleshoot this further? The debug log doesn't show any additional info. Can I turn on additional debug logging by modifying the ini file since I can't do it through the plugin interface?
This what my current ini looks like:
Al
C:\Program Files\HomeSeer HS3>hspi_ultralog3 UltraLog3 HSPI starting... Connecting to HomeSeer server at 127.0.0.1, attempt 1... Connection to HomeSeer at 127.0.0.1, attempt 1 succeeded. Entered InitIO() function. Entered Version() function. UltraLog3 version 3.0.5468.35007 initializing...
Initializing plug-in(2): UltraLog3 Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
[Settings] Version=3.0.5468.35007 [Syslog] StartListen=1 Severity=5
Al
