I'm upgrading from HS2 to HS3 but would like to retain the facility of monitoring any generated x10 signals whether the device is registered with Homeseer or not. This includes any signals generated by hand held remotes.
I was told that UltraLog is the best route so I've downloaded a trial version.
I'd like to ask a few questions.
1 ) Upon installation I believe that 2 items were added to my HS3 device list:
UltrLog3 Plug-in and SysLog Logger. What should the fields "Floor" and "Room" contain for these 2 entries.
2) I have a motion sensor in one of the rooms. If I actually switch it to "ON" through the device manager in Homeseer I get the message "Device: Ground Hallway Motion Sensor 2 to On (100) by/from: CAPI Control Handler" which seems perfectly fine.
However if I stand in front of the sensor and I can see that it's been activated, the motion is not registered in the log and nor are any x10 signals which are generated from hand held remotes.
Is there a step I the installation process that I've missed.
Thank you
Thank you
