UltraLog3 Error
    UltraLog3 Error
    Randy,
    I have been using Ultralog just to search for certain things in the log. Love the interface and find it very user-friendly. Today, for the first time, I use it in an event. I wanted to have all of my new temperature sensors by HS polled each time I connect to HS3 from my iPhone, in order to have the most current temperature readings. Ultralog came in handy in the event creation, since I could trigger an event based on my iPhone being connected, as reflected in the log. Here is a snapshot of the event:
    Everything seems to work on my first test, but I did get an error in the log after the event was triggered:
    Any ideas on what might be wrong? Is that because I haven't filled the last line in the triggers?
    When I developed the UltraLog3 plug-in, HS didn't used to indicate reading a variable that doesn't exist as an error. My plug-in first tries to read the variable, then creates if it doesn't exist. You can ignore that when you see it in the logs.
    Ultrajones
