Global Variable Errors
    I often see these errors at startup:-
    19/04/2016 10:00:43 ~!~Error~!~A call was made to save a global variable (SyslogHostname) but there are none defined in the system.
    19/04/2016 10:00:43 ~!~Error~!~A call was made to save a global variable (SyslogMsgTag) but that global variable has not been defined.
    19/04/2016 10:00:43 ~!~Error~!~A call was made to save a global variable (SyslogMsgContent) but that global variable has not been defined.Startup Complete, 3 errors detected, check the log for more information.
    I check in the global variables and sysloghostname, syslogmsgcontent and syslogmsgtag are defined and I can see information stored in the values.
    Why do I get these errors?
    These "Errors" are not really errors. A recent version of HomeSeer started to indicate they were errors when in fact they are not. You'll only see those "errors" once when a regex match triggers and the data is stored in a HomeSeer variable. They won't keep appearing.
    Ultrajones
      I get them all the time when homeseer starts up.
      On the odd occasion it starts up clear.
      Annoying, as i dont like seeing errors.
      Feb-26 07:30:19
      Informational
      UltraLog3 HSPI capture variable "SyslogMsgTag" ready for use. See HomeSeer GetVar API for usage.
      Feb-26 07:30:19
      Error
      Feb-26 07:30:19
      Informational
      UltraLog3 HSPI capture variable "SyslogMsgContent" ready for use. See HomeSeer GetVar API for usage.
      Feb-26 07:30:19
      Error
      Feb-26 07:30:19
      Informational
      UltraLog3 HSPI capture variable "SyslogHostname" ready for use. See HomeSeer GetVar API for usage.
      Feb-26 07:30:19
      Error
