Ultralog and syslog from Mikrotik
    Hi
    I have set up, or at least tried, to set up Ultralog to receive syslogs from my Mikrotik router. I also set up the router to log to disk. The log looks like this in the log-file:
    Oct/26/2016 20:48:00 system,info log rule changed by admin
    I do not get anything in the syslog in Ultralog.
    Is it the format of the log-string that is the problem?
    The plugin is set up like this:
    Enable syslog on startup: Yes
    Logging severity: Debug
    IP Address:
    Port:
    My Mikrotik i set up to send syslog events to the IP of my HS-server on port 514
    //Morten
    Just to make sure, hVe you ruled out any any firewall issues?
    Originally posted by rprade
      No I have not. But there is no firewall blocking traffic internally.
      However I did a quick test now and tried telnet from another computer to my hs on port 514. No response. Did the same from my HS computer, no response. So it seems like there is nothing listening on port 514 on my HS-server.
        Are you you running HS on windows or Linux?
          Running on windows 7
          Edit: I installed a 3party syslog software on another computer and redirected my syslog events from my router to that one and it works as it should. When I change back to HS-server as my receiver of syslogs no events are received.
            Try completely turning the the windows firewall off.
