while trying to populate the floorplan, i can't select any devices or select any fields other than the floor and in the upper left corner it says its still loading homeseer devices. Any idea? Worth mentioning, I get the pop-up alert in IE, if I click yes, allow I get here, if i click no, i can select the boxes, but not click load
ultra view install
MeSteveTags: None
Try using the updated config tool:
http://board.homeseer.com/attachment...achmentid=3737
Right-click, and select "Save Target As...", then save to your HomeSeer/html directory.
Let me know if that works.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Is Ultraview still picky about the device names? If I remember correctly it didn't like certain characters and/or spaces. That had me going for a while!--------------------------------------------------
**** Do You "Cocoon"? ****
MeSteve
The attachment did the trick, thanks. It loaded all the devices in the cfg file, but nothing on the floorplan yet. I ran the ultra_view2_xml.txt file
