I am trying to sort my motion detectors in the status display in date/time of the last change order. I set the device string to strdevicelastchange ( date time) in the Ultra_View2_xml.inc file, but the displayed order is not chrolological. If I set the string to idevicetime (minutes since last change) the order is OK, but it is limited to whole minutes and makes determining the direction of movement difficult.
Is there a way to sort the on the strldevicelastchange value in chronolical order?
The format is '2/4/2005 10:50:39 PM'
I am using- sort select="STRING" data-type = "number" order="descending"
<xsl:for-each select="DEVICE">
<xsl:sort select="STRING" data-type = "number" order="descending" />
<xsl:if test="TYPE = 'MS13A (Hawkeye II)'or LOCATION = 'Joist'">
<tr>
<td class="tableroweven" width="45%" valign="top" align="left">
<xsl:value-of select="NAME" />
</td>
<td class="tablerowodd" width="10%" valign="top" align="left">
<xsl:apply-templates select="ICON
</td>
<xsl:apply-templates select="STRING" />
</td>
</tr>
</xsl:if>
</xsl:for-each>
<tr>
</td>
</td>
</td>
</tr>
</xsl:if>
</xsl:for-each>
