Ultra View Status Error
    I have been trying to get the status view working for some time now. When I run the ultra_view2_xml.vbs script on my 2003 Server I get the following error
    Line 21
    Char 1
    Error Expected statement
    Code 800A0400
    Source MS VBScript compilation error
    I have tried everything but cant get this to work, any ideas?
    Do you have the ultra_view2.cfg file in the "C:\Program Files\HomeSeer\scripts" directory? If not, create it and put the following code in the file:
    function GetLocation(strDeviceID)
      dim arrLocation
      select case strDeviceID
        case else arrLocation = array(-100, -100, 1, 0)
      end select
      GetLocation = arrLocation
    end function
      I do have that file with the following code in it.
      dim arrLocation
      end select
      end function
        Did you put the include files in the /HomeSeer/include directory?
          ultra_view2_common.inc
          ultra_view2_diskio.inc
          ultra_view2_html.inc
          ultra_view2_xml.inc
          These are the files found in the include directory.
            Kevin,
            that was include, not includes - right? UltraSuite installs to include.
              That is correct. I suspect the problem has to do with the application being run on 2003 Server. I have tried everything I can think of to make this work and nothing seems to help.
              Sure will be cool once I get this running. ML will be next and then I plan on jumping into RFID.
