Release Status:
A test version of UltraView2 / UltraStatus HSPI is now available. I am looking for feedback on what issue you experience in getting UltraView2 up and running.
Note: This test version will expire 1/1/2006. A non-test version will be release prior to the expire date.
Quick Start Documentation:
http://www.wideopenwest.com/~ultrajo...ltrastatus.zip
Note: It was created with Wink and it's about 7 MB in size.
If you're having problems, please post them in this thread. I may not have time to answer questions right way, so I hope that other using UltraView / UltraView2 HSPI can help answer some of them.
Feature Requests:
Known Issues:
Troubleshooting Hints:
Ultrajones
Feature Requests:
- Have ultraview2_config.aspx default to the first floor [DONE].
- Ability to specify the number of floors supported (e.g. basement, 1st floor, 2nd floor). <br>The floors are currently hard coded in ultraview2.txt and the configuration tool as (basement = floor_0.gif, 1st floor = floor_1.gif, 2nd floor = floor_2.gif)
- Ability to specify the image path instead of the default (e.g. /images/HomeSeer).
Known Issues:
- Back up your existing hspi_ultrastatus.xml file. If you following the quick start document, it will overwrite the existing hspi_ultrastatus.xml file. Sorry about that Steven...
- Make sure each of the following URL's load completly without error:<br>
http://localhost/status?pg=xml_status <br>
http://localhost/status?pg=xml_devices <br>
http://localhost/status?pg=xml_locations <br>
Ultrajones
