new questin with ultraview/status
  • Ultrajones
    At this time, all images must be in the /images/HomeSeer directory.
    You can change the image path based on the HomeSeer device type by editing the ProcessDevice() function within the ultraview2_common.txt file and the PlaceImages() subroutine in the ultraview2.txt file.
    You'll need to make sure the image path is set correctly before this part of ultraview2.txt, PlaceImages() code executes:
    PHP Code:
    Adjust image properties based on XML node data
    objImage.src = strImagePath & strIcon
    objImage.Style.Left = iX
    objImage.Style.Top = iY
    objImage.Title = strToolTip
    Note: If you edit these files, make sure you make a backup before attempting to install HSPI UltraStatus updates via the HomeSeer2 updater.
    Regards,
    Ultrajones
  • unibits
    Ultrajones:
    I did as you asked. It can't display the the page or at least that is the error it displays.
    I looked at the url and i see what the problem is I think.
    This icon http://localhost/images/HomeSeer/TonyStewart-142.gif does not actually exist on the path that ultraview displays.
    It actually exists in :localhost/images/TonyStewart-142.gif
    I did some checking nd in the old ultraview I set the case for all the nascar images as well as all icons and then they would properly display.
    Is there a way to set the case for personal user icons other than the ones that are imbedded within homeseer?
    thanks again for you time
    David
  • Ultrajones
    Click the icon, then select properties. Copy the address (URL), then paste it into the Address line of the browser. Does it image display?
  • unibits
    started a topic new questin with ultraview/status
    Ultrajones:
    Thanks for the recent updates to the ultrastatus package. I have been able to get all the devices to populate as they should.
    I can't seem to figure out how to get devices to show up where they may contain data such as the case with my WANIP
    The icon is not displayed however when I hover over it it says the location of where it should be. I then check to see if the ican is there and it is however, the log says it is unable to display icon .....
    I cant seem to figure it out???
    Can you help
    thanks
    David
