Status indication from devices
  • Status indication from devices
    Hi, after installing Ultraview/ultraStatus I see in the HS homepage that device A5 is Enabled. I made in UltraStatus a device string rule.
    After removing the rule I did not get the origin status indication back.
    When I change the status form A5 I do not see the ON/OFF status change on the homepage.
    You can see it in RED the attatchment.
    How can I get the original HS statusindication back?
    Thanks for help
    Theo Wieleman
    Thanks for help
    Theo Wieleman
    Excellent question. From the HomeSeer web interface, select control, then under "Immediate Script Command" enter:
    &hs.SetDeviceString "A5", ""
    Ultrajones
      Device indacator works again ! Yes, Yes, Yes !
      Excellent Answer Ultrajones !!
      It works !
      Thanks a lot !
      Theo Wieleman
      The Netherlands
