Without success I have been trying to have a second set of Ultraview2.aspx pages (including the uv2~~.txt pages, etc) running from a 2nd directory. Then with the UV2-config.aspx I generated a 2nd XML file (not named ultraview2.xml)
Even when I replace in this 2nd directory all 'Ultraview2' occurencies with e.g. 'UltraviewX' through all these files, still the Ultraview2.xml file is used.
When I rename my newly generated xml file as Ultraview2.xml, everything just works fine (except of course that my first set of UV2 pages is incorrect now )
What am I overlooking in this?
Is the file ultraview2.xml somewhere hardcoded?
Pls help !
Henk
Pls help !
Henk
