Special Status
  • Guest's Avatar
    Guest replied
    Many thanks!
  • Ultrajones
    I suggest you use the web interface... but if you want to edit the file, it is HomeSeer 2\Config\hspi_ultrastatus.xml
  • Guest's Avatar
    Guest replied
    Originally posted by Ultrajones
    I assume your using the HSPI UltraStatus plug-in...
    Do you have a rule defined for the house and unit code of the IRLinc? If so, you'll need to adjust the "On String" to "AV on" and the "Off String" to "AV Off".
    Does that help?
    Ultrajones,
    Yes. Can you let me know where/which file to adjust this string?
    Many thanks!
  • Ultrajones
    Does that help?
  • Guest's Avatar
    Guest started a topic Special Status
    Special Status
    I just rebuild my HS PC and everything are perfect except one minor problem... Please help if you can.
    My IRLinc showing my audio light on/off is working BUT picking up as "Light on" and "Light off" instead of I want "AV on" and "AV off" in status. I have been looking for many hours everywhere but I can't find where to edit these infos. I am sure it is very simple edit/change. Please point me to a right place to edit/correct this problem. Many thanks in advance!
