Incorrect floorplan gif shown
  • Incorrect floorplan gif shown
    When I go to the ultraview 2 page (http://localhost/ultraview2/ultraview2.aspx), I see the default floorplan (floor_1) even though I built a new one called firstfloor.gif and loaded in using the config. I wonder, is there a limitation on the type of gif (bit and dither)? Doubt it but worth a try. I even tried renaming mine to floor_1 but that didn't work. I'm also getting some webserver errors. Included is an excerpt from the log.
    5/24/2006 8:38:03 PM - Debug - BuildDeviceArray() took 1.07437499999651 seconds
    5/24/2006 8:38:03 PM - Debug - BuildDeviceArray() took 0.964999999996508 seconds
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/degrees/t87.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/TantoTempoRemixes.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/NotMuted.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayingSemContencaoByBebelGilberto.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Stopped.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayanAlbum.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/NoShuffle.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayaPlayList.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayanArtist.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Loop.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayaGenre.gif
    5/24/2006 8:38:05 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Enabled.gif
    question about aspx file
    In the ultraview.aspx file, we are asked to modify the following code regarding height and width.
    <!-- SPECIFY THE HEIGHT AND WIDTH OF YOUR FLOOR PLAN IMAGE BELOW --> img id="floor" style="LEFT: 0px; POSITION: relative; TOP: 0px" height="279" src="/images/HomeSeer/floor_1.gif" width="500" border="0"
    The name of the gif remains floor_1.gif which is the default file. Where are the new floorplan gif files annunciated? Right now, it is reading the floor_1 and not the floorplan gifs. I'm trying to see where you added the second floor and the basement in the code but don't see the var.
      Progress
      Saw a post that said the floor plans need to be labeled either floor_1 or floor_2. This seemed to have a better effect. I'm still getting all of those webserver errors associated with the itunes plugin. It is obvious that ultraview is trying to find a gif associated with each of those devices but the itunes and mediaplayer devices don't have gifs. How do I deselect those devices from ultraview? Also, I saw on Ultrajones' site some temperature gifs for the RCS plugin. I can't find those on my hard drive. Did I miss those in the installation? Can someone look for, say, the t86.gif on their system and tell me where it is?
      5/25/2006 9:09:18 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Loop.gif
      5/25/2006 9:09:18 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Enabled.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Notesandthelike.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/degrees/t86.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayingLinebylineByMs.JohnSoda.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/NotMuted.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/degrees/t83.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Loop.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayanAlbum.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayanArtist.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayaGenre.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/PlayaPlayList.gif
      5/25/2006 9:09:20 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/NoShuffle.gif
      5/25/2006 9:09:21 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Stopped.gif
      5/25/2006 9:09:21 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/.gif
      5/25/2006 9:09:21 PM - Error - Web Server Error 404, cannot serve file: C:\Program Files\HomeSeer 2\html/images/HomeSeer/Enabled.gif
        I think I can come up with a work-around... I'll add something to the config page so you can mark a device hidden.
        I'll try to post something tomorrow.
        Ultrajones
          I added an option to the "Floor" config to hide devices. Try this config tool out and let me know if it works for you.
          Ultrajones
