UltraStatus Rules
  • UltraStatus Rules
    Hey Guys,
    Right, I did have a big question here, but I worked it out for myseld. But I do have another quick question. Is there a way to put HTML in the rule string ? for example < B > Door Open < / B > ??
    Many thanks
    Marc
    Yes, rules can support HTML.
      Hmm, that's interesting. I did originally try putting <b> and </b> in one of the rules.. when I did, I had some problems.
      I had A10 set to ON=OPEN OFF=CLOSED
      I had A1 set to ON=ARMED and OFF=DISARMED
      When I sent an A1 ON then ultrastatus set A1 to OPEN, not ARMED.
      Once I removed the HTML, it worked perfectly again.
      Am I missing something ?
      Many Thanks
      Marc
        OK, seems there is something strange going on here. Even if I remove all html I am still getting the wrong status put onto a device.
        As above, when A1 turns on, it's showing FIRE DETECTED instead of ARMED. I've rechecked the rules and they all look ok....
        <img src="http://194.164.238.206/albums/Miscellaneous/ultra3.jpg">
        If I remove A10 and A11 from the Fire Sensor rule, then the Alarm Status rule starts working correctly !
        Anyone able to help ? Please ??
          Download the version I just uploaded to the Updater to see if the change I made helps.
          Ultrajones
            Hey Ultra,
            Thanks for the reply ! Unfortunatley the update did not help. I am still seeing this problem.
            I have listed the config file below.. obviously I had to remove some of the code that effected me posting it.
            RuleItem ID="1150904120" Name="DuskDawn Sensor" Enabled="True" DevOn="Night Time" DevOff="Day Time" DevOther="Unknown" DevCodes="B6" Logging="True"
            RuleItem ID="1150904839" Name="Fire Sensor" Enabled="True" DevOn="FIRE DETECTED" DevOff="All Clear" DevOther="Unknown" DevCodes="A4,A7,A8,A9,A10,A11" Logging="True"
            RuleItem ID="1150905460" Name="Motion Sensor" Enabled="True" DevOn="MOTION DETECTED" DevOff="Idle" DevOther="Unknown" DevCodes="A2,B2,B8" Logging="True"
            RuleItem ID="1150905607" Name="Magnetic Sensor" Enabled="True" DevOn="OPEN" DevOff="Closed" DevOther="Unknown" DevCodes="A5,A6" Logging="True"
            RuleItem ID="1150906773" Name="Alarm Status" Enabled="True" DevOn="ARMED" DevOff="DISARMED" DevOther="Unknown" DevCodes="A1" Logging="True"
            Many Thanks
            Marc
              Please restart HomeSeer, then post the version info for HSPI UltraStatus.
              Ultrajones
                Hey Ultra,
                OK, the info is below....
                04/07/2006 08:41:11 Info Found plug-in: UltraStatus, version: 1.0.2362.31794
                04/07/2006 08:41:18 UltraStatus Info UltraStatus version 1.0.2362 starting ...
                HSPI_ULTRASTATUS.dll 1.0.2362.31794
                Many Thanks
                Marc
                  Version 1.0.2369 contains the fix. You're running 1.0.2362. It's available via the updater.
                    Ah ok... this is weird.
                    I actually did run the updater earlier, but hadn't noticed this in the log...
                    04/07/2006 16:34:14 Updater Starting installation of updates
                    04/07/2006 16:34:14 Updater Applying update: UltraStatus
                    04/07/2006 16:34:14 Updater Copying file: c:\program files\homeseer 2\HSPI_ULTRASTATUS.dll
                    04/07/2006 16:34:14 Updater Error Unable to install files, is HomeSeer running? Please exit it now if so. (Retry in 5 sec.)
                    04/07/2006 16:34:19 Updater Copying file: c:\program files\homeseer 2\HSPI_ULTRASTATUS.dll
                    04/07/2006 16:34:19 Updater Error Unable to install files, is HomeSeer running? Please exit it now if so. (Retry in 5 sec.)
                    04/07/2006 16:34:19 Updater Error Error installing file: HSPI_ULTRASTATUS.dll , is file open?
                    04/07/2006 16:34:19 Updater Error Detailed error: 0
                    04/07/2006 16:34:19 Updater Error Installation aborted.
                    04/07/2006 16:34:19 Updater Error Installation of package UltraStatus failed. Installation will be attempted the next time the application is started.
                    04/07/2006 16:34:19 Updater Installation of updates completed, but one or more were unsuccessful and will be attemped again at the next restart.
                    I'll try to delete the file manually and report back !
                      OK, looks like it installed correctly now.. but..
                      04/07/2006 16:41:13 Error Initializing interface: UltraStatus->InitIO() failed. HSPI not initialized correctly.
                      So I looked into hspi_ultrastatus_debug.log and saw this..
                      4/07/2006 16:39:08...UltraStatus Warning~~!~~This test version has expired.
                      04/07/2006 16:39:08...UltraStatus Info~~!~~UltraStatus - initializing I/O ...
                      04/07/2006 16:39:54...UltraStatus Info~~!~~UltraStatus - shutting down I/O ...
                      04/07/2006 16:41:13...UltraStatus Warning~~!~~This test version has expired.
                      04/07/2006 16:41:13...UltraStatus Info~~!~~UltraStatus - initializing I/O ...
                      Any help appreciated.
                      Marc
                        What the ... That code no longer exists ...
                        I'll recompled the program and uploaded a new version. Please try downloading again. The new version is 1.0.2376.19978.
                          OK, this is getting very weird now.
                          I don't know if my updater is broken or what, but if I go into updater I see this...
                          No UltraStatus Plug-in 1.0.2376.19978 1.0.2369.28882 Free Ultrajones
                          So I put a tick next to it and click next. I then get the downloading pending box and eventually the "You need to restart homeseer" box. So I restart Homeseer, but it's still showing the same version. I checked the Updates2 directory and UltraStatus is not there.. it's not even downloading it :\
                          I'm guessing my updater must be knackered.
                            Ultra,
                            It appears that I can't downlaod the newest version..
                            05/07/2006 10:32:19 Updater Retrieving updates control file...
                            05/07/2006 10:34:11 Updater Starting download of updates
                            05/07/2006 10:34:11 Updater Downloading update: UltraStatus
                            05/07/2006 10:34:11 Updater Error downloading file: The remote server returned an error: (404) Not Found.
                            It's weird as the updater says it was done, but the log shows differently. I guess I need to submit that to HST as a bug. so, it looks as if it can't find the file to download from your site.
                            Appreciate your help.
                            Marc
                              I am getting the same 404 error when I try to download the latest version, also.
