Ultraview message - XML refresh failed
  • Ultraview message - XML refresh failed
    Hi to all,
    I wonder if you can help me.
    I've installed this plugin, enabled it, performed a configuration via the web interface (it found all my homeseer devices ok). Worked out the hard coded .gif file names for the floorplans ok. Unfortunately, when I load the ultraview web page, I see no devices on the floor plan, and the message window says
    22/06/2006 22:22:00..Timer initialised
    22/06/2006 22:22:00..XML refresh failed.
    Selecting the other floorplan causes this to be displayed ok, the message window reports it has 'switch to floor 1 complete', but then reports the XML refresh has failed again.
    My knowledge of XML is very minor, but I would love to get this plugin to work correctly. Any pointers/advise is most welcome.
    Ian.
    I haver the same problem, have you find a solution ?
      Test your xml's files with :
      http://localhost/hspi_ultrastatus/hs...action=xmltest
