Hi to all,
I wonder if you can help me.
I've installed this plugin, enabled it, performed a configuration via the web interface (it found all my homeseer devices ok). Worked out the hard coded .gif file names for the floorplans ok. Unfortunately, when I load the ultraview web page, I see no devices on the floor plan, and the message window says
22/06/2006 22:22:00..Timer initialised
22/06/2006 22:22:00..XML refresh failed.
Selecting the other floorplan causes this to be displayed ok, the message window reports it has 'switch to floor 1 complete', but then reports the XML refresh has failed again.
My knowledge of XML is very minor, but I would love to get this plugin to work correctly. Any pointers/advise is most welcome.
Regards,
Ian.
Regards,
Ian.
