UltraStatus & Extended device Codes.
    #16
    Thanks.
    So how do I get the icon from my custom web page. If I use for example
    hs.devicestring("A1")
    and turn the device on, I get the text that I have entered for the on string but I do not get the icon ?
    Thanks.
    Phill
      #17
      Originally posted by mlagase
      Did the non X10 devices not make it in to the latest release?
      I still only see X10 device codes, unless I am missing something in my config.
      Mike
      You can always just edit the XML file, seems to work for me. Just create the rule as you would want, and select a bogus device address. Save it, then edit the XML and change the bogus address to the extended address you want (i.e. "^1"). I'm sure Ultra will get around to it. In the meantime, as I said, this seems to work for me.
      Brian
        #18
        Brian
        that is what I do and it works great....
          #19
          Same here...
          --Dan
          Tasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
            #20
            I'll give that a try
            Mike
              #21
              mlagase,
              A bit of advise, when you change the "data" file to add in the !@#$%^&* charactors, to get the system to respond immediatly, go in to the web settings, then change something, then change it back. Or create a new rule, then delete it (just something to get the plugin to re-read the database of rules).
              --Dan
                #22
                Originally posted by drozwood90
                mlagase,
                --Dan
                you know i always have trouble with that.. at first.. but yeah once you get the new one up it seems fine.. but that first time... can be a hair pulling drinkin time....
                  #23
                  I'm having much more luck getting the desired results just editing the XML file too.
                    #24
                    That's the way to do it!
                    --Dan
