still getting no device error..
  • still getting no device error..
    when i run this code http://xxx.xxx.xxx.xxx:yyyy/status?pg=xml_positions , I get the following error any ideas ?????
    ICON="/ultraview2/position.gif" R="0" X="-100" Y="-100" Z="1" />
    <DEVICE ID="deva226" CODE="#2" NAME="Is Speaking Speak-In" TYPE="Is Speaking" LOCATION="Is Speaking" ICON="/ultraview2/position.gif" R="0" X="-100" Y="-100" Z="1" />
    <DEVICE ID
    The XML page cannot be displayed
    Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
    Required white space was missing. Error processing resource 'http://111.112.113.11:81/status?pg=xml_positions'. Line 1, Po...
    <DEVICE ID="deva6830" CODE="`1" NAME="Any Player" TYPE="virtual" LOCATION="Music" ICON="/ultraview2/position.gif" R="0" X...
    N>="deva7002" CODE="B9" NAME="Sink Switch 1" TYPE="Wall Keypad" LOCATION="Kitchen" ICON="/ultraview2/position.gif" R="0" X="-100" Y="-100" Z="1" />
    <DEVICE ID
    It's kinda hard to tell what device is causing the issue based on the info you provided. The info you copy and pasted is truncated.
    Example:
      That's the way the page gives it to me.. I don't think that's the problem ,, I beleave the problem is in the line that folows which I appeared to have some how truncated.. somehow the file this info is coming from appears to be getting out of sync .. I think.. maybe right after the music icon position it appears not to be completed ie R="0" X="-100" Y="-100" Z="1" /> and it also appears to be missing the <DEVICE ID.. Any ideas ???
      sent it as a notepad attachment it appears to be cause the html of the page to kick in
