Memory usage
    Memory usage
    Since loading UltraStatus the other day I saw Homeseer's memory (as indicated in Taskmanager/VM Size column) increase to over 200MB after a less than a day of running. I disabled UltraStatus and that figure stays at less than 100 MB.
    Any ideas???
    Edit:
    After having UltraStatus turned off for a day, Homeseer memory usage is climbing well above the 'normal' <100MB (Virtual Memory) I used to see. I guess UltraStatus isn't the cause.
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
    RAM, I am running the same HomeSeer version and I am not seeing memory usage increase. I'll keep and eye on it today and let you know if I see anything unusual.
    Ultrajones
