Ultraview file error message
  • Ultraview file error message
    When I load my ultraview page I get the following error message in my HS log file. I repeats for a seemingly random number of times (between 20 and 34) for my main floor display. I have 31 'on/off' (regular light bulb type on/off) icons on this main page plus 2 'car' icons plus 1 'thermostat' icon.
    1/2/2007 8:14:41 AM ~!~ERROR~!~InTCPSendFile: File 'C:\Program Files\HomeSeer 2\html/ultraview2/' not found.
    It appears I'm getting an error message for the icon files it displays, yet all the icons display properly. I do not get any error messages if I change floors and do an update, even if I re-load the main floor.
    Any ideas why I'm getting the error messages?
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
    Using the config tool, did you set all the items you are not displaying to "hidden"?
      How do you set them to 'hidden'? I do not see anything like that on the config webpage.
      All of the items I am not displaying show up in the .xml config file like so:
      device ref="deva7413" x="-100" y="-100" f="1" z="0"
      while a displayed item looks like so:
      device ref="deva2181" x="242" y="171" f="1" z="0"
      (leading < & trailing /> symbols left off so the line would show on message board.)
      Does that look right?
      Dick
        I found the 'hidden' setup option. That appears to fix the problem, plus the page loads much faster, I assume since it isn't trying to do load all the f=1 devices I'm not using. There must have been one huge pile of them off-screen at location -100,-100.
        Dick
          There was This is the reason I recently modified the plug-in to default everything to hidden. I just need to do one more update so dragging the icon to the floor plan changes it to "floor 1" if the user hasn't already selected another floor.
          Ultrajones
