How do i change the "A:ok.gif" to "Aok.gif"
    I want to show my RCS Thermostat on my floorplan. I can't because the thermostat reports the status with
    PHP Code:
    A:ok
    . I can't save a gif with the colon in the filename.
    Where do i go to make the thermostat report anything i want it to?
    Is there a script, a file, or is it hardcoded?
    Which themostat are you using? You could always process the colon out using something like.
    sVal = "A:Ok"
    r = replace(sval,":")
    After processing r will equal AOK
    -Rupp
      sVal = "A:Ok"
      Its a txb16. But where do i make the sVal comment. Which file?
        I would think you could do this within the UltraStatus processing.
        -Rupp
          The device string processing is in a function called BuildIcon() in the C:\Program Files\HomeSeer 2\html\ultraview2\ultraview2_common.txt file. Just add a new call to strip() as follows:
          PHP Code:
          Remove unwanted characters
          strIcon = Strip(strIcon, ":", "")
          strIcon = Strip(strIcon, "°.*|degrees|\s", "")
          strIcon = Strip(strIcon, "\([^\)]*\)", "")
          You could also do a replace a Rupp indicated in that same function instead of using the Strip function.
          Ultrajones
            PHP Code:
            Ultrajones
            That did it Ultra. Thanks again!
