Can't configure UltraStatus
    I just repeated the downloaded of UltraStatus from the Updater, but when I select the Config button on the setup screen the web page refreshes, but no configuration page appears. I have restarted HS a couple of times. There are no errors in the HS log and the interface is reporting it is ok. (There was an error in the first download - that's when I redid it.)
    Updater Error - Installation of package UltraStatus failed. The installation file 'HSPI_ULTRASTATUS_1.0.2555.22338.zip' does not exist. Please retry download.
    Any suggestions of next steps? What more information will be helpful?
    Did you seen anything installed prior to this message? In my experience, this is a bogus error written by older version of HomeSeer 2.
      Yes, to my untrained eye the installation seemed to go ok, but I could not access UltraStatus after the first try (that's when I saw the message). After repeating the download, I could then access the UltraStatus page, but got another error about a duplicate registration. I could not find any duplication, so I continued. That's when I found I got no response to the config button. I can get to UltraStatus and input rules, but when I go to UltraView it will not let me load the configuration file saying there are no devices. I assumed that was because I had not performed a required setup step in configuring the plug in.
      All this was some time ago, but if it would help I can try to retrieve the relevant parts of the HS log, if I still have those log files.
