Can not change the device string of HomeSeer devices
    Hello,
    I have homeseer2 v2.2.0.11
    HSPI UltraView2
    I want to change the device string of HomeSeer devices but I can`t. What is going wrong?
    XML test ok.
    <LEGEND>Device String Rule </LEGEND><TABLE border=0><TBODY><TR><TD>Rule Name:</TD><TD><INPUT id=txtRuleName value=Doors name=txtRuleName> </TD></TR><TR><TD>On String:</TD><TD><INPUT id=txtDevOn value="Door Open" name=txtDevOn> </TD></TR><TR><TD>Off String:</TD><TD><INPUT id=txtDevOff value="Door Closed" name=txtDevOff> </TD></TR><TR><TD>Other:</TD><TD><INPUT id=txtDevOther value=Unknown name=txtDevOther> </TD></TR><TR><TD>Rule Enabled:</TD><TD><SELECT id=selRuleEnabled name=selRuleEnabled> <OPTION value=True selected>True</OPTION> <OPTION value=False>False</OPTION></SELECT></TD></TR><TR><TD>Logging Enabled:</TD><TD><SELECT id=selLoggingEnabled name=selLoggingEnabled> <OPTION value=True selected>True</OPTION> <OPTION value=False>False</OPTION></SELECT></TD></TR><TR><TD colSpan=2>Trigger Rule When The Following Devices Change Status:</TD></TR><TR><TD colSpan=2><TABLE style="BORDER-COLLAPSE: collapse" cellSpacing=1 border=0><TBODY><TR><TD>HC</TD><TD>UC</TD><TD>Action</TD><TD rowSpan=2><SELECT id=lstDeviceCodes size=8 name=lstDeviceCodes> <OPTION value=[18>[18</OPTION></SELECT> </TD></TR><TR><TD vAlign=top><SELECT id=selHC name=selHC> <OPTION value=# selected># []</OPTION> <OPTION value=$>$ []</OPTION> <OPTION value=%>% []</OPTION> <OPTION value=&>& [Ultra1Wire]</OPTION> <OPTION value=[>[ [HomeVision]</OPTION> <OPTION value=\>\ [HomeVision]</OPTION> <OPTION value=]>] [HomeVision]</OPTION> <OPTION value=^>^ [UltraMon]</OPTION> <OPTION value=_>_ [UltraStatus]</OPTION> <OPTION value=">" OPTION [UltraLog]<><OPTION value=A>A []</OPTION> <OPTION value=B>B []</OPTION> <OPTION value=C>C []</OPTION> <OPTION value=R>R [mcsTemperature]</OPTION> <OPTION value=V>V []</OPTION></SELECT></TD><TD vAlign=top><SELECT id=selUC name=selUC> <OPTION value=1 selected>1</OPTION> <OPTION value=2>2</OPTION> <OPTION value=3>3</OPTION> <OPTION value=4>4</OPTION> <OPTION value=5>5</OPTION> <OPTION value=6>6</OPTION> <OPTION value=7>7</OPTION> <OPTION value=8>8</OPTION> <OPTION value=9>9</OPTION> <OPTION value=10>10</OPTION> <OPTION value=11>11</OPTION> <OPTION value=12>12</OPTION> <OPTION value=13>13</OPTION> <OPTION value=14>14</OPTION> <OPTION value=15>15</OPTION> <OPTION value=16>16</OPTION> <OPTION value=17>17</OPTION> <OPTION value=18>18</OPTION> <OPTION value=19>19</OPTION> <OPTION value=20>20</OPTION> <OPTION value=21>21</OPTION> <OPTION value=22>22</OPTION> <OPTION value=23>23</OPTION> <OPTION value=24>24</OPTION> <OPTION value=25>25</OPTION> <OPTION value=26>26</OPTION> <OPTION value=27>27</OPTION> <OPTION value=28>28</OPTION> <OPTION value=29>29</OPTION> <OPTION value=30>30</OPTION> <OPTION value=31>31</OPTION> <OPTION value=32>32</OPTION> <OPTION value=33>33</OPTION> <OPTION value=34>34</OPTION> <OPTION value=35>35</OPTION> <OPTION value=36>36</OPTION> <OPTION value=37>37</OPTION> <OPTION value=38>38</OPTION> <OPTION value=39>39</OPTION> <OPTION value=40>40</OPTION> <OPTION value=41>41</OPTION> <OPTION value=42>42</OPTION> <OPTION value=43>43</OPTION> <OPTION value=44>44</OPTION> <OPTION value=45>45</OPTION> <OPTION value=46>46</OPTION> <OPTION value=47>47</OPTION> <OPTION value=48>48</OPTION> <OPTION value=49>49</OPTION> <OPTION value=50>50</OPTION> <OPTION value=51>51</OPTION> <OPTION value=52>52</OPTION> <OPTION value=53>53</OPTION> <OPTION value=54>54</OPTION> <OPTION value=55>55</OPTION> <OPTION value=56>56</OPTION> <OPTION value=57>57</OPTION> <OPTION value=58>58</OPTION> <OPTION value=59>59</OPTION> <OPTION value=60>60</OPTION> <OPTION value=61>61</OPTION> <OPTION value=62>62</OPTION> <OPTION value=63>63</OPTION> <OPTION value=64>64</OPTION> <OPTION value=65>65</OPTION> <OPTION value=66>66</OPTION> <OPTION value=67>67</OPTION> <OPTION value=68>68</OPTION> <OPTION value=69>69</OPTION> <OPTION value=70>70</OPTION> <OPTION value=71>71</OPTION> <OPTION value=72>72</OPTION> <OPTION value=73>73</OPTION> <OPTION value=74>74</OPTION> <OPTION value=75>75</OPTION> <OPTION value=76>76</OPTION> <OPTION value=77>77</OPTION> <OPTION value=78>78</OPTION> <OPTION value=79>79</OPTION> <OPTION value=80>80</OPTION> <OPTION value=81>81</OPTION> <OPTION value=82>82</OPTION> <OPTION value=83>83</OPTION> <OPTION value=84>84</OPTION> <OPTION value=85>85</OPTION> <OPTION value=86>86</OPTION> <OPTION value=87>87</OPTION> <OPTION value=88>88</OPTION> <OPTION value=89>89</OPTION> <OPTION value=90>90</OPTION> <OPTION value=91>91</OPTION> <OPTION value=92>92</OPTION> <OPTION value=93>93</OPTION> <OPTION value=94>94</OPTION> <OPTION value=95>95</OPTION> <OPTION value=96>96</OPTION> <OPTION value=97>97</OPTION> <OPTION value=98>98</OPTION> <OPTION value=99>99</OPTION></SELECT></TD><TD vAlign=top><INPUT id=btnDevCodeDelete title=Remove type=submit value="<<" name=btnDevCodeDelete> <INPUT id=btnDevCodeAdd title=Add type=submit value=">>" name=btnDevCodeAdd> </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
    Where I put the gif and what must be the name of the gif?
    C:\Program Files\HomeSeer 2\html\Images\HomeSeer
    Thanks in advance
    renaatdb
    What is the [18 device? What plug-in owns it?
    In the example you provided, images would be place in:
    And the images should be:
      different gifs for HV digital inputs
      [18 is a HomeVision Digital Input
      The gif is related to
      http://localhost:3000/images/HomeSeer/on.gif
      All the HV Digital inputs are related to the Homeseer/on.gif
      But I want other gifs for different digital inputs.
      How I can solve this problem?
      renaatdb
