Ultra, I have installed, per your readme, the Ultra Suite. I am interested in the Ultra_View2. When I try to use the Ultra_View2_Config.asp page, after I add my image, I do a HomeSeer device "LOAD" off the page and I get the error, "Unable to talk with HomeSeer." I tried looking through your code and I am not sure what the issue is. I am running HS 1.6.186, have all of the min. Ultra software installed.
I have test code I use that tests the connection to HomeSeer with .asp:
<%@ LANGUAGE=VBScript %>
DIM hs
Set hs = CreateObject("HomeSeer.Application")
response.write hs.DeviceStatus("C2")
response.write "<br>"
if (hs.DeviceStatus("C2") = 2) then
hs.ExecX10 "C2", "off"
response.write "C2 [Device] is now off"
else
hs.ExecX10 "C2", "on"
response.write "C2 [Device] is now on"
end if
Set hs = Nothing
and I have no problem connecting or changing the state of the HS Device. I have another .asp page that Queries all of the HomeSeer devices, and it works from both the web server of HS and IIS. So I know that the ActiveX/HS connection is working. Any ideas on what I need to look for to correct this?
I have an old HouseLinc and Plato software that has a floorplan, but no Internet access to view it. Thanks for your time in helping with this problem. Mark
DIM hs
else
end if
Set hs = Nothing
