Setup problems: ultra_view2_config.htm fails...
    Hi
    I am having problems getting ultraview setup and configured.
    <UL TYPE=SQUARE>
    <LI>I installed the files in the appropriate locations (the include files are in html/include) from ultra_suite 1.0.4
    <LI>I edited ultra_view2.asp and modified the settings for my first floor image.
    <LI>I modified ultra_view2.txt to indicate the three different floor plans.
    <LI>I ran ultra_view2_config.htm (from the file system not from the web server), loaded my images and clicked LOAD.
    <LI>I went ahead and ran ultra_view2_xml.txt. No errors[/list]
    At that point a dialog pops up saying "63 devices found". I click ok, the dialog goes away and nothing else happens. The configuration tool seems to hang and the "Device Image Placement" buttons/options never become active. My devices show up in http://localhost:81/ultra_view2_control.asp and ultra_view2_status.asp; and the floor plans show up in ultra_view2.asp. There are no obvious errors in the log file other than missing device icons.
    So I'm stumped. I've gone back and rechecked everything. Since I could not get the config tool to work I made certain that ultra_view2.cfg was in the script directory as indicated in "Ultra View Status.html". Still no luck.
    A couple of possible clues:
    <UL TYPE=SQUARE>
    <LI>When the configuration tool hangs it is on the first device, the Security Status for the OnQ Plugin, Device "[1".
    <LI>If I try to open ultra_view2_xml.vbs via the web server I never get any xml?
    <LI>If I try to run ultra_view2_xml.vbs directly (from the file system) I receive a "Windows VBScript compilation Error" pointing to Line 21, character 1 with Error "Expected Statement" and Code 800A0400[/list]
    I am appending a screen shot of the config page after I have loaded the images.
    Any suggestions?
    Barry
    This make take some time... Can you send me an email (ultrajones@hotmail.com) so I can work with you on this. I will be modifying the ultra_view2_config.htm so it reports errors correctly. The program is probably choking on your device names or device house codes.
    Ultrajones
      Ultra,
      Any progress on this issue?
      bhenderson
        Do you have an ultra_view2.cfg file in your HomeSeer/scripts directory?
        If not, place the ultra_view2.cfg file in your HomeSeer/scripts directory, then point your web browser to http://localhost/ultra_view2_xml.vbs
        Let me know if you can see XML in your web browser and that it parses completly without errors.
          Ultrajones,
          I do have ultra_view2.cfg in the scripts directory. And I do get what appears to be correct XML output. I have attached the output.
          bhenderson
            Try this and let me know what the dispayed errors are...
            Note: Use right-click, Save Target As...
              Thanks Ultrajones!
              That did it?!
              No errors! The floor plan images loaded and the configuration sailed right through the devices. I added a couple to test it and they showed up fine when I loaded ultra_view2.asp. Don't know what you did but Thanks!
              bhenderson
