Display of Device Last Change
    Hi,
    how do I display the 'Last Change' properties of a device in HS in an UltraView Table, I presume that I add a new '<TD>' to the xsl file in question but what is the code to call the 'Last Change' in HS.
    What I have is;
    <xsl:apply-templates select="LASTCHANGE"
    but this is not showing any data, even though there is data within HS.
    Any suggestions?
    Lance
    Lance
    It looks like nobody has answered this posting. I'm dealing with the same issue and looking for the answer. I tried but with no luck with the following "CHANGE" variable.
    <tr>
    <td class="tablecolumn" valign="top" align="left">Location</td>
    <td class="tablecolumn" valign="top" align="left">Status</td>
    <td class="tablecolumn" valign="top" align="left">Last Change</td>
    </tr>
    <xsl:for-each select="DEVICE">
    <xsl:sort select="LOCATION" order="ascending" />
    <xsl:sort select="TYPE" order="ascending" />
    <xsl:if test="TYPE = 'Interface I/O' and LOCATION != 'Secu16 Unit 1'">
    <tr>
    <td class="tableroweven" width="60%" valign="top" align="left">
    <xsl:value-of select="LOCATION" /> [<xsl:value-of select="NAME" />]
    </td>
    <td class="tablerowodd" width="15%" valign="top" align="left">
    <xsl:value-of select="STRING" disable-output-escaping="yes"/>
    </td>
    <td class="tablerowodd" width="25%" valign="top" align="left">
    <xsl:value-of select="CHANGE" />
    </td>
    </tr>
    </xsl:if>
    </xsl:for-each>
      Got it! It's "@CHANGE"
        Sorry... I replied to the original post in a different forum. You are correct, the @CHANGE is the attribute you were looking for.
