Double-Posting
  • Double-Posting
    When I goto options and press refresh two times i get Double-Posting in the log and the IE windows just goes blank.
    I can't see that i have any Double-Posting, where can i check this.
    Jonas, Sweden
    Jonas, Sweden
    This was code to prevent (and ignore) the ASPX double-posting bug in HomeSeer prior to verison 2.1.0.0. Is there any reason you are pressing refresh within a second of each other? I'll remove that code in the next update.
      When i change an object i can get the double posting error, I just clicked every where to see if i got the error anywhere else.
      I still have the problem that the plugin is disabled when my HS restarts, and i have to enable the plugin.
      What files do i need to delete to make i clean installation of Ultrastatus.
      Jonas, Sweden
        You just need to re-install via the HomeSeer updater. What version of HomeSeer are you running?
          v 2.2.0.66
