Help with error...
  • Help with error...
    When running the XML Tests I get this error:
    <TABLE cellSpacing=1 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tableroweven vAlign=top>Status</TD><TD class=tableroweven vAlign=top>/status?pg=xml_status</TD><TD class=tableroweven>Pass
    </TD></TR><TR><TD class=tablerowodd vAlign=top>Devices</TD><TD class=tablerowodd vAlign=top>/status?pg=xml_devices</TD><TD class=tablerowodd>Pass
    </TD></TR><TR><TD class=tableroweven vAlign=top>Locations</TD><TD class=tableroweven vAlign=top>/status?pg=xml_location</TD><TD class=tableroweven>Pass
    </TD></TR><TR><TD class=tablerowodd vAlign=top>Positions</TD><TD class=tablerowodd vAlign=top>/status?pg=xml_positions</TD><TD class=tablerowodd>Fail
    An error occurred in the "doXMLTest()" function.The error details are:Parse Error...-1072898027Line Number...1Character.....5413Description...The attribute 'width' on this element is not defined in the DTD/Schema.
    </PRE>
    </TD></TR></TBODY></TABLE></P>
    So I then run just that one and get this at the bottom:
    <DEVICE ID="deva3842" CODE="^11" NAME="Cara Keychain" TYPE="BLRfid Plug-In Device" LOCATION="BLRfid" ICON="/images/BLRfid/out_of_range.gif" R="0" X="-100" Y="-100" Z="-2" />
    <DEVICE ID="deva9939" CODE="`2" NAME="Security Mode" TYPE="BLSecurity Plug-In Device" LOCATION="BLSecurity" ICON="images/BLSecurity/disarmed.gif" R="0" X="-100" Y="-100" Z="-2" />
    <DEVICE ID="deva3026" CODE="[13" NAME="Perimeter Alarm Lighting" TYPE="Insteon Group/Scene" LOCATION="BLSecurity" ICON="/images/HomeSeer/Off.gif" R="0" X="-100" Y="-100" Z="-2" />
    <DEVICE ID="deva3602" CODE="`3" NAME="Last Alert Device" TYPE="BLSecurity Plug- <TABLE width=400>
    The XML page cannot be displayed Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later. <HR>End tag 'td' does not match the start tag 'DEVICEDATA'. Error processing resource 'http://192.168.1.5/status?pg=xml_positio...
    <TBODY></TBODY>
    </TABLE>
    <DEVICE id=deva5202 ICON="...</font" LOCATION="Holiday" TYPE="Insteon ICON ApplianceLinc Outlet" NAME="Outside Blowups" CODE="]13">
    </PRE>In Device
    " LOCATION="BLSecurity" ICON="images/BLSecurity/alarm-alert.gif" R="0" X="-100" Y="-100" Z="-2" />
    <DEVICE ID="deva5106" CODE="`1" NAME="Security Status" TYPE="BLSecurity Plug-In Device" LOCATION="BLSecurity" ICON="images/BLSecurity/alarm-normal.gif" R="0" X="-100" Y="-100" Z="-2" />
    So what is this trying to tell me?
    Any help would be appreciated.
    Bryan
    Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
    Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
    Hi there;
    I ad the same problem sometime ago I think it happens because of the '
    , But never had the time to prove it..
    HTH (Hope this helps)
      This is strange... It appears the "type" for device code "`3" contains HTML:
      PHP Code:
      TYPE="BLSecurity Plug- <TABLE width=400></b><br />"
      I'll add code to strip out any HTML and will post an update later today.
      Ultrajones
        Thanks guys, look forward to the update.
        Bryan
          I posted an update that should fix that error. Please test and let me know if you stil have issues.
          By the way, does Blade know you're cheating on his plug-ins?
            lol, thanks Ultra. I'll test this in the morning.
            I'm actually writing a touch screen package and want to make sure it's compatible with both UltraView2 and BLFloorplan. It's just about ready for beta testing!
            But more on that later!
            Bryan
              Strange ... I don't see where your seeing
              PHP Code:
              <table width="400"
              anywhere??
              I've reinstalled this plug-in and have deleted and remade several devices to try and solve this but with each device I delete and recreate it just throws another up with a similar error. I would tend to believe that my database is somewhat screwed up!
              Is there anyway to actually see the HS database? I think this is the only way to see where the actual problem is.
              this is the latest error:
              PHP Code:
                <DEVICE ID="deva9441" CODE="`2" NAME="Security Mode" TYPE="BLSecurity Plug-In Device" LOCATION="BLSecurity" LOCATION2="" ICON="images/BLSecurity/disarmed.gif" R="0" X="-100" Y="-100" Z="-2" />
              DEVICE ID="deva3257" CODE="`1" NAME="Security Status" TYPE="BLSecurity Plug-In Device" LOCATION="BLSecurity" LOCATION2="" ICON="images/BLSecurity/alarm-normal.gif" R="0" X="-100" Y="-100" Z="-2" />
              End tag 'td' does not match the start tag 'DEVICEDATA'Error processing resource 'http://192.168.1.5/status?pg=xml_positio...
              <DEVICE ID="deva9650" CODE="Y34" NAME="Humidity - Outside" TYPE="Status Only" LOCATION="Info" LOCATION2="" ICON="/images/...
              V>
                <DEVICE ID="deva7997" CODE="[13" NAME="Perimeter Alarm Lighting" TYPE="Insteon Group/Scene" LOCATION="BLSecurity" LOCATION2="" ICON="/images/HomeSeer/Off.gif" R="0" X="-100" Y="-100" Z="-2" />
              Bryan
                It's *really* hard to see the real error because I think the message board is mess with the data you're posting. Please do the following:
                From http://localhost:80/hspi_ultraview2.aspx?action=xmltest, right-click on the "/status?pg=xml_positions" url, then select "Save Target As .. ", then save the status.xml file. Please email the xml file to ultrajones@hotmail.com.
                Ultrajones
                  Fixed
                  Ultrajones;;
                  Don't know what you did but I know pass the XML tests...
                  DEM
