Probem of test ultraview2
MACHUTags: None
The UltraView2 Quick Start Documentation shows you a way to determine what character is causing the XML to fail to load. Can you review
http://automatedhomeonline.com/HomeS...ultraview2.htm to see if that procedure helps you find the cause? The instructions are about 1/4 way into the demonstration. In summary, you need to open up IE, then navigate to http://127.0.0.1:80/status?pg=xml_devices. Once that page loads, scroll to the bottom of the page to see if you see the text the XML parse fails on. You should see the ending </DEVICEDATA> XML element.
Note: The above example assumes your HomeSeer web server is listening on 127.0.0.1 on port 80.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
ukdavros
I seem to be getting a similar error
Fail
An error occurred in the "doXMLTest()" function.
The error details are:
Parse Error...-1072896760
Line Number...3552
Character.....15264
Description...An invalid character was found in text content.
Followed the quick start and when I schroll to the bottom of the XML page, doesnt appear to be any errors
I get the DEVICEDATA bit but nothing after it
HomeSeer Version: Standard Edition 2.2.0.66
HomeSeer: Is Registered
HomeSeer Localization: English (United Kingdom)
Operating System: Microsoft Windows XP Professional - Work Station
OS Version: 5.1.2600 Service Pack: 3.0
System Uptime: 0 Days 1 Hour 12 Minutes 32 Seconds
UltraStatus
UltraStatus
UltraView2
N/A HSPI_ULTRASTATUS.dll 1.1.3172.37875
Mark
ukdavros
