HI, I finally bought the Alexa plug-in, it had previously worked under the free test periodbut I had not used it for awhile the testing and purchase.
When I enable the registered version it goes to a green "OK" status, then it changes to red "CRITICAL: Plugin has disconnected".
nothing discernable in the log.
Then it keeps trying to initialize but fails. any ideas?
Here's a snippet of the log filtered for "Alexa" events
Oct-25 04:26:01 | Warning | I/O interface Alexa is down, executable is not running, restarting ... |
Oct-25 04:25:33 | Info | Plugin Alexa with instance: has disconnected |
Oct-25 04:25:32 | Starting Plug-In | Plugin Alexa started successfully in 400 milliseconds |
Oct-25 04:25:31 | Alexa | INFO Alexa version 3.0.0.1 |
Oct-25 04:25:31 | Starting Plug-In | Initializing plugin Alexa ... |
Oct-25 04:25:31 | Starting Plug-In | Alexa loaded in 15012 milliseconds |
Oct-25 04:25:16 | Info | Plugin Alexa has connected. IP:127.0.0.1:61200 |
Oct-25 04:25:16 | Warning | I/O interface Alexa is down, executable is not running, restarting ... |
Oct-25 04:24:48 | Info | Plugin Alexa with instance: has disconnected |
Oct-25 04:24:46 | Starting Plug-In | Plugin Alexa started successfully in 450 milliseconds |
Oct-25 04:24:46 | Alexa | INFO Alexa version 3.0.0.1 |
Oct-25 04:24:46 | Starting Plug-In | Initializing plugin Alexa ... |
Oct-25 04:24:46 | Starting Plug-In | Alexa loaded in 15011 milliseconds |
Oct-25 04:24:31 | Info | Plugin Alexa has connected. IP:127.0.0.1:61147 |
Oct-25 04:24:31 | Warning | I/O interface Alexa is down, executable is not running, restarting ... |
Oct-25 04:24:02 | Info | Plugin Alexa with instance: has disconnected |
Oct-25 04:24:01 | Starting Plug-In | Plugin Alexa started successfully in 427 milliseconds |
Oct-25 04:24:00 | Alexa | INFO Alexa version 3.0.0.1 |
Oct-25 04:24:00 | Starting Plug-In | Initializing plugin Alexa ... |
Oct-25 04:24:00 | Starting Plug-In | Alexa loaded in 15022 milliseconds |
Oct-25 04:23:45 | Info | Plugin Alexa has connected. IP:127.0.0.1:61091 |
Oct-25 04:23:45 | Warning | I/O interface Alexa is down, executable is not running, restarting ... |
Oct-25 04:23:17 | Info | Plugin Alexa with instance: has disconnected |
Oct-25 04:23:15 | Starting Plug-In | Plugin Alexa started successfully in 426 milliseconds |
Oct-25 04:23:15 | Alexa | INFO Alexa version 3.0.0.1 |
Oct-25 04:23:15 | Starting Plug-In | Initializing plugin Alexa ... |
Oct-25 04:23:15 | Starting Plug-In | Alexa loaded in 15004 milliseconds |
Oct-25 04:23:00 | Info | Plugin Alexa has connected. IP:127.0.0.1:61035 |
Oct-25 04:23:00 | Warning | I/O interface Alexa is down, executable is not running, restarting ... |
Oct-25 04:22:33 | Info | Plugin Alexa with instance: has disconnected |
Oct-25 04:22:30 | Plug-In | Finished initializing plug-in Alexa |
Oct-25 04:22:30 | Starting Plug-In | Alexa loaded in 662 milliseconds |
Oct-25 04:22:30 | Starting Plug-In | Plugin Alexa started successfully in 432 milliseconds |
Oct-25 04:22:30 | Alexa | INFO Alexa version 3.0.0.1 |
Oct-25 04:22:30 | Starting Plug-In | Initializing plugin Alexa ... |
Oct-25 04:22:29 | Info | Plugin Alexa has connected. IP:127.0.0.1:60993 |
Oct-25 04:16:07 | Info | Plugin Alexa with instance: has disconnected |
Oct-25 04:16:05 | Plug-In | Finished initializing plug-in Alexa |
Oct-25 04:16:05 | Starting Plug-In | Alexa loaded in 776 milliseconds |
Oct-25 04:16:05 | Starting Plug-In | Plugin Alexa started successfully in 429 milliseconds |
Oct-25 04:16:05 | Alexa | INFO Alexa version 3.0.0.1 |
Oct-25 04:16:05 | Starting Plug-In | Initializing plugin Alexa ... |
Oct-25 04:16:04 | Info | Plugin Alexa has connected. IP:127.0.0.1:60563 |
Oct-25 04:11:23 | Plug-In | Found plug-in: Alexa, version: 3.0.0.1 |
