Error message
  • #16
    I've had a little play!
    I can get it to work fine by pressing the Test button in 'Settings'.
    I have enabled Attention phrase recognition, however I have not managed to get Alexa's attention automatically.
    I am using Windows 10 and have Cortana enabled - could this be the problem?
    Cortana recognises what I say.
    • #17
      could you set the log level to Trace, restart the plugin and try to say Alexa and then post the logs you get
      • #18
        This is from the HS log;
        Oct-07 13:34:07
        Info
        Plugin Alexa with instance: test has disconnected
        Oct-07 13:33:55
        Alexa
        TRACE Phrase rejected = Alexa
        Oct-07 13:33:55
        Alexa
        TRACE Phrase hypothesized = Alexa, Confidence=0.003097128
        Oct-07 13:33:55
        Alexa
        TRACE Speech Detected:
        Oct-07 13:33:54
        Alexa
        TRACE Phrase recognized but confidence=0.7685943 is lower than threshold
        Oct-07 13:33:53
        Alexa
        TRACE Phrase hypothesized = Alexa, Confidence=0.7655728
        Oct-07 13:33:53
        Alexa
        Oct-07 13:33:44
        Alexa
        TRACE Phrase recognized but confidence=0.2550898 is lower than threshold
        Oct-07 13:33:43
        Alexa
        TRACE Phrase hypothesized = Alexa, Confidence=0.09580276
        Oct-07 13:33:43
        Alexa
        Oct-07 13:33:31
        Alexa
        TRACE Phrase recognized but confidence=0.7560757 is lower than threshold
        Oct-07 13:33:31
        Alexa
        TRACE Phrase hypothesized = Alexa, Confidence=0.8672175
        Oct-07 13:33:31
        Alexa
        Oct-07 13:33:14
        Alexa
        DEBUG Speech Recognition Started
        • #19
          Suggests to me that my microphone isn't picking up - but its fine for Cortana and when I use it on Skype. The microphone in use is built into my Logitech webcam.
          • #20
            you can try to change the attention phrase to something different from Alexa. Also you can try to use a different language runtime, there are different ones for British, Canadian, Australian, US accents:https://www.microsoft.com/en-us/down....aspx?id=27224
            Also you can lower the confidence threshold.
            • #21
              I'll have a play.
