BLControl in Google Play
This is a sticky topic.
  • BLControl in Google Play
    BLControl app is now in Google Play
    BLControl App
    PLEASE NOTE:
    The app is not much use right now because the plugin is not released yet. The plugin should be released this week.
    The BLControl app is considered BETA, which means there will be issues but I wanted to get it out so people could try it before I go on vacation at the end of November.
    Cheers,
    Bob
    I have posted 1.0.1 to Google Play. It should be there later tonight
    Cheers,
    Bob
      I have posted 1.0.2 to Google Play. It should be there soon.
      Cheers,
      Bob
        I posted 1.0.3 to Google Play. It should be there soon
        I changed the app icon
        Cheers,
        Bob
          Hi Blade,
          I have loaded the app and entered the IP and port for Homeseer and understand that it wont connect but when the app is trying to connect it keeps trying to until I get an error saying that the app has stoped and there is no way of stopping this or getting back to the setup page to change the ip and port.
          I guess if someone puts in the wrong ip or it changes then I cant see a way of getting this changes.
          Greig.
          Scripts =
          Various
            I have just tried to update the app and I get an error (update for "BLControl" could not be downloaded due to an error.(404)
            would this be because the service is still running as I cant shut the app properly?
            I will try and uninstall.
            Greig
            Scripts =
            Various
              Originally posted by enigmatheatre View Post
              Hi Blade,
              Greig.
              Good point. I will have to give the option to go to the settings page
              Cheers,
              Bob
                Greig
                You would think Android should be smart enough to uninstall and reinstall.
                Cheers,
                Bob
                  BTW... the port you enter will be the one you assign in the BLControl plugin in HS3
                  Cheers,
                  Bob
                    Even if when the app was trying to connect if the Back button stopped the connection and went back to the main page.
                    I did uninstall and reinstall and all is well.
                    I use 2660
                    I did think this would be the case.
                    Greig.
                    Scripts =
                    Various
                      I have posted 1.0.5 to Google Play.
                      It will allow you to get to the settings page if the connection fails.
                      Cheers,
                      Bob
                        How do you do it............ I think you must be vader and use mind control to program things.
                        Greig.
                        Scripts =
                        Various
                          installing..... will let you know..
                            install went fine and when the connection fails I get the no server connection pop up. I can then go to settings but then how do I make the app connect as when I press back in the settings page the app crashes.
                            Greig.
                            Scripts =
                            Various
                              If you press the app icon in the upper left with the left arrow does that work?
                              I did that here and it worked.
                              Cheers,
                              Bob
