BLControl in Google Play
This is a sticky topic.
  • #31
    I will be releasing a new build soon. Google Play seems to be down and I cannot upload it.
    I will upload it as soon as I can
    Here are the changes:
    - fixed the back button on all screens
    - the back button on the main screen now allows you to completely close the app or let it run in the background
    - added crash report functionality - so if the app crashes you will be prompted to email me the crash log.
    Cheers,
    Bob
    • #32
      1.0.8 is posted to Google Play. It should be there soon
      Cheers,
      Bob
      • #33
        Re: BLControl in Google Play
        Bob, excellent work! Looms like this could be a real replacement for HSTouch.
        How are you addressing the android disconnect issues? Would like to use this on permapowered tablets.
        Transitioning to HS3Pro .298 - WinXPEmbedded
        Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
        • #34
          What do you mean by disconnects?
          Cheers,
          Bob
          • #35
            I mean keeping the app always connected. Android tends to close apps that are not used which causes issues like missed HSTouch messages, lag in connecting from cold starts, etc.
            In other words, does your app drop connections like that HSTouch?
            Is this a good option for tablets that are always connected?
            • #36
              When you press back on the main screen it will give you the option to close it completely or run it in the background. When it is running in the background it will still be connected to the plugin on the HS side.
              In the app you can set a keep alive number of minutes. After there is not activity the specified number of minutes then the app will completely disconnect.
              Cheers,
              Bob
              • #37
                I have posted 1.0.17 to Google Play. It should be there soon
                This fixes a bunch of bugs.
                I also have debug logging working in this new build so you will be able to go to the settings page and turn on debug logging, then capture the issue and then go back to the settings page and disable logging. Once you disable logging it will prompt you for an email app and will send the log to me.
                Let me know how things are working
                The HS log page still does not work. Waiting on a fix from Rich for this.
                Cheers,
                Bob
                • #38
                  I have posted 1.0.18 to Google Play.
                  You will need to update the plugin to 1.0.9 as well
                  The HomeSeer log should now show in the app.
                  You can specify how many previous hours of log info will be shown. This setting is in the plugin
                  Cheers,
                  Bob
                  • #39
                    I have posted 1.0.19 to Google Play
                    You will need to update the plugin to 1.0.10 as well
                    I have added the following:
                    - BLLock integration (BLLock build 2.0.15 requied)
                    - Attempt to fix device load
                    Cheers,
                    Bob
                    • #40
                      1.0.20 is posted to Google Play
                      You will need to update the plugin to 1.0.12
                      I have added BLStat into this build. You will need the latest BLStat as well for it to work properly.
                      This will be the last build until after I return from vacation in mid December.
                      Cheers,
                      Bob
                      • #41
                        Does the app support widgets?
