latest BLcontrol gives 404 error
  • latest BLcontrol gives 404 error
    Blade when downloading the latest BLcontrol today I get a 404 error form the server
    Thanks Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
    The plugin or the app?
    The plugin is on dropbox. Sometimes they seem to have problems.
    Cheers,
    Bob
      the plugin.
      I have the latest app installed but can't get eh plugin.
      Cheers Ken
        That is weird. I can see if on my dropbox.
        Here is the public link:
        https://dl.dropboxusercontent.com/u/...l_1-0-25-0.zip
        If you download it manually you will have to install it manually
        1. Shutdown HS3
        2. Download the above link
        3. All you need to do is extract the HSPI_BLControl.exe to the following folders
        [your HS root folder]
        [your HS root folder]\html\bin
        4. Restart HS3
        Try that and let me know
        Cheers,
        Bob
          Ok blade that got the new plugin but I cant connect the app to it I get a message in the app "THe BLControl server has shutdown so all clients will be disconnected. The application will now close"
          Any ideas
          Thanks Ken
            Force close the app and run it again
            I have seen this too and will check into why that happens
            Cheers,
            Bob
              I have tried quite a few time to force it closed and restart but it still is not connecting?
              Cheers Ken
                Very odd. I had it happen to me about an hour ago and all I did was restart the app.
                Try going to the plugin options page and stopping and starting the server.
                Then try the app again.
                Cheers,
                Bob
                  Blade no luck with this either I am unable to connect at all??
                  I tried to restart the server, then I completely restarted HS3, and even rebooted the PC and still no luck
                  Cheers Ken
                    OK something has to be up on your end because I used it all day and night yesterday with no issues.
                    What error are you getting?
                    Have you tried completely restarting your phone?
                    Cheers,
                    Bob
                      I have run it a bunch of times today as well and I have had no issues.
                      I did update the plugin and app today so you could try those if you want but something must be up on your end.
                      Is anyone else having issues?
                      Cheers,
                      Bob
                        Ok blade going to install the latest updates but I am still getting the 404 error is the link the same as the previous posted one for dropbox
                        Cheers Ken
                          The link is different
                          https://dl.dropboxusercontent.com/u/...l_1-0-27-0.zip
                          I am not having any issue updating the plugin from the HS3 updater. It is very odd that you are having an issue
                          Cheers,
                          Bob
                            Cheers Ken
                            Hey Ken,
                            Blade sent me a link to this thread hoping I might be able to help.
                            I don't suppose you might be willing to let me remote into your machine and take a look at your install? It sounds to me like something network related which just happens to be something I'm good at. I was a System Admin for almost 15 years before leaving the company I was at to raise my son.
                            If your willing and interested, we can use whatever program you want if you already have one you like, or I can supply you with a setup link to logmein.
                            I'm in Los Angeles, and should be up from about 7am on, however my son has been in a foul mood the last week so don't be surprised if it takes me an hour to respond, I will certainly be looking for a reply.
                            Nathan
                              Nathan I really appreciate the help. I am in Wisconsin and will be home after 3pm our time. Please send me the link for logmein and I would love the help. IM not a computer guy at all and could really use the help
                              Thanks ken
                              Sent from my EVO using Tapatalk
